04:38 AM
Sep 26, 2013
04:38 AM
Hi Everybody.
Did anyone work with the TriBoard, TC275 and PLS UAD2pro debugger?
If yes, how can one connect via JTAG? I create a default config file for the TC275 but
always get the message that the CFG might not be correct...
Thanks ,
Joerg
Thanks ,
Joerg
02:25 AM
Oct 24, 2013
02:25 AM
You might want to check with PLS.
04:30 AM
Aug 28, 2014
04:30 AM
Hi Joerg,
I am having a similar issue with UAD debugger, can you explain what the issue was and how were you able to solve the issue.
03:12 AM
Oct 30, 2014
03:12 AM
Hi all,
I am having similar problem with Hightec development platform and PLS UAD2 emulator. i am using application kit tc2x5 having TC275TP controller.issues are,
1.The bsp template not available for this board
2.jatag debug configuration files are not available for controller
so while connecting the target 'No jtag client found' error is coming.
tc275A and tc275B jtag configuration available but that is not for TC275TP and i am not sure whether these configuration can be used or not.
can anybody help me?
Digesh
Digesh
