TC275 Programming
BaselImad
First like given 5 sign-ins First question asked
Hi All
We have designed a Control unit based on TC275 MCU, and we want to programe it using this tool "KIT_MINIWIGGLER_3_USB", so could you please check if we are using the right pin out for the connector?
Please see attached picture for the Programmer connector on the board.
Basel Tahboub
MoD
50 likes received 500 replies posted 100 solutions authored
No, this is not correct.
Pin 10 must be connected to PORST and not to TRST.
Anupama_A
50 solutions authored 10 likes received 250 sign-ins
MoD
Anupama_A
Hi @BaselImad ,
Sorry for the mistake in my last comment. Please refer to the table 6-1 in this document which mentions that Pin 10 (which is the RESET pin as mentioned in table 3-1) should be connected to PORST.
Anupama.
