SWYoon
25 sign-ins 10 sign-ins 5 sign-ins
MultiCAN_AI.047 Transmit Frame Corruption after Protocol Exception (CAN FD only) is included in Functional Deviations in TC264BC errrta sheet(TC26x_BC_Errata_Sheet_v1_3.pdf).
Can you explain what this errata is about?
In conclusion, does this mean that node 4 cannot be used when using CAN FD?
Di_W
Dear User,
As the errata described, the wrong frame can be detected. The below  chart showed the Arbitration field which has ID/RRS bits. As the wrong frame is only send at specific situration(which is described in the errata), then Node 4 still can be used in common situration.
dw
Di_W
Dear User,
dw
