Oct 08, 2020
01:13 AM
Oct 08, 2020
01:13 AM
Hello Everybody,
I try to find the worst case for accuracy for frequency measurement. The frequency of the input signal is between 100Hz to 15kHz at the input of the µC.
We used GTM timers at configured at 4MHz.
Tolerance and temperature drift for the Quartz at 20Mhz is 0.03%
I would like to know, the influence of the jitter on the PLL of the microcontroler with modulated clock at 1%.
Withtout taking account the jitter, in worst case we could have +/- one period of the GTM_timers according to the synchronisation of the edge, is it right?
To measure 100Hz, the number of the edge of GTM_timer will be : 40000
To measure 15kHz, the number of the edge of GTM_timer will be : 266.7
How can I compute of the effect of the jitter for the PLL at 4MHz?
-According to the datasheet, JtotCC = 12.2ns and DPCC is +/-200ps
Do I only need to add the time of the Peak_Period_Jitter to the period of the GTM_timers?
Thank you for your help,
ES
ES
06:02 AM
Oct 08, 2020
06:02 AM
Nice work - yes, you add one period of GTM and JtotCC together.
See AP32244 AURIX SYSPLL Frequency Modulation for a very long discussion of PLL modulation effects on short and long term jitter.
Oct 08, 2020
08:13 AM
Oct 08, 2020
08:13 AM
Thank you for your answer.
I add the JtotCC one the tranfert function.
Input informations
Etime is the worst case time with the noise calculated from simulation for the electronic part. 41ns in our case.
Results :
ES
