TC237 connect to host PC through UART(ASC)
Hi, there!
Recently, I purchased TC237 kit to prepare motor contest.
Unfortunately, I have a problem now.
I want to use UART(ASC) but the terminal in my host PC cannot display any results.
DAS is installed in my PC. Also USB dirvers are detected and installed automatically. But any com ports expect my printer are not exited.
How can I connect my TC237 to PC through USB port?
Thank you in advance!
Possibly your "VCP" is not enabled in the USB settings in Device manager.
Path: USB Controllers / Infineon DAS JDS COM/ Properties/ Advanced / "Enable VCP"
Then, remove and reconnect your USB port
