leonng
First like given 10 questions asked 10 replies posted
Hi there,
I'm following iLLD, "http://doc.tasking.com/act/illd_1_0_0_11_0/TC23x/html/group___ifx_lld___cpu___trap___usage.html", to use the NMI.
Then, I check the memory and find that ESR1 is enabled and it was triggered. However, there is nothing happened(turn on LED).
What did I miss? Thank you.
Leon
Prudhvi
25 likes received 50 solutions authored 250 sign-ins
Hello Leon,
It's a user hook function intended for users to implement their own exception handling mechanism. Hence you'll find switch cases with no code. User should extend their code there.
Prudhvi.
Prudhvi
We're unable to access the link that you shared. Can you please share in accessible format?
You may refer to the below link for code examples related to Trap available from Infineon with the name CPU_Trap_Recognition_1_KIT_xxx:
https://github.com/Infineon/AURIX_code_examples/tree/master/code_examples
Prudhvi.
TBencher
250 replies posted First like given 50 sign-ins
Hi Prudhvi,
the link is accessible.
TBencher
TBencher
Hi leonng,
that could have several reasons. Please could you provide the whole code segment?
Which Trap Class and Trap ID did you use in your code?
TBencher
leonng
Thank you for your response.
Link: http://doc.tasking.com/act/illd_1_0_0_11_0/TC23x/html/group___ifx_lld___cpu___trap___usage.html
Class: non-Maskable Interrupt (NMI)
Actually, it can trigger the NMI. Then, the code is operating, when it is put in the library file "ifxCpu_Trap.c", like below.
The code that copies from ILLD seems meaningless:
Did I miss something?
There is another related question post on https://community.infineon.com/t5/AURIX/SPI-exchange-during-a-Trap/m-p/349870#M7617. Would you mind giving me some help or idea? Thank you.
I'm trying to read the error list from TLF35584 after it triggers NMI. Since I use SPI interrupt, it causes the SPI to keep busy.
Is there a command to end the NMI and go to another function? Or any other simple way?
Leon
Prudhvi
Hello Leon,
Prudhvi.
