TC233 CAN error bit0
User17875
hi everyone.
I have got some problem that my CAN is not working using iLLD example source.
it is working well on tc233 triboard
canNodeConfig.nodeId = (IfxMultican_NodeId)((int)IfxMultican_NodeId_0);
canNodeConfig.rxPin = &IfxMultican_RXD0E_P33_7_IN;
canNodeConfig.rxPinMode = IfxPort_InputMode_pullUp;
canNodeConfig.txPin = &IfxMultican_TXD0_P33_8_OUT;
canNodeConfig.txPinMode = IfxPort_OutputMode_pushPull;
canNodeConfig.transferInterrupt.enabled = FALSE;
canNodeConfig.alertInterrupt.enabled = FALSE;
IfxMultican_Can_Node_init(&g_Can.drivers.lCanNode, &canNodeConfig);
/* Initialize Node 1 */
canNodeConfig.nodeId = (IfxMultican_NodeId)((int)IfxMultican_NodeId_1);
canNodeConfig.rxPin = &IfxMultican_RXD1B_P14_1_IN;
canNodeConfig.txPin = &IfxMultican_TXD1_P14_0_OUT;
IfxMultican_Can_Node_init(&g_Can.drivers.vCanNode, &canNodeConfig);
but not working on custom board, tc234
canNodeConfig.rxPin = &IfxMultican_RXD1A_P15_3_IN;
canNodeConfig.txPin = &IfxMultican_TXD1_P15_2_OUT;
/* Initialize Node for Vehicle CAN */
canNodeConfig.nodeId = (IfxMultican_NodeId)((int)IfxMultican_NodeId_2);
canNodeConfig.rxPin = &IfxMultican_RXD2A_P15_1_IN;
canNodeConfig.txPin = &IfxMultican_TXD2_P15_0_OUT;
everything is same and i just changed PINs.
and i have tested both of triboard tc233, applicationKit tc234. then working well.
the error is bit0
5168.attach
please, tell me how to solve it or what should i check.
Thank you.
