05:31 AM
Jun 09, 2017
05:31 AM
Hi everyone,
I'm new in Infineon and this forum. I started to work on TC1797 Tricore with DAVE 2. I watched a video which explain to start coding with DAVE in here; http://www.edge-cdn.net/index.php?ct=1353&vid=140502&setlang=en
I did all steps in the video but in UDE section, my compile process failed and I met this error ;
WARNING: Controller0.Core::UDEMemtool: FLASH programming for device '2 MByte OnChip Program FLASH (Demo)' not available !
ERROR: Controller0.Core::PFLASH1: Initializing FLASH driver on target failed
WARNING: Controller0.Core::UDEMemtool: FLASH programming for device '2 MByte OnChip Program FLASH (2) (Demo)' not available !
ERROR: Controller0.Core::FLASH: Initializing FLASH driver on target failed
WARNING: Controller0.Core::UDEMemtool: FLASH programming for device '64 KByte OnChip Data FLASH (Demo)' not available !
MSG: Controller0.Core::UDEDebugServer: Connection to TC1797 target monitor established: TriCore (Core), ID: 1015A083h
WARNING: Controller0.Core::UDEDebugServer: CRC check after download failed in memory range from 81000000H to 81004EEFH!
WARNING: Controller0.Core::UDEDebugServer: CRC check after download failed in memory range from 81004EF0H to 81004F0FH!
MSG: Controller0.Core::UDEDebugServer: Program with ID 0x1 - code size 20240 bytes - was loaded!
I don't know should I use JTAG or DAP? I set up DAS and Memtool only but I can't establish connection between PC and board like in the video so I cant't change flash memory and I can't do blinky. Should I set up another program from CD which is in the kit? Thank you for your advice.
04:01 AM
Jun 14, 2017
04:01 AM
Hi sumeyye,
check your DAS connection. Should be like in the attached screenshot.
Cheers, Martin
Cheers, Martin
01:21 AM
Jun 19, 2017
01:21 AM
Martin firstly thank you for your reply. I checked all of these and my DAS connection is like you. There isn't any problem. But I run Memtool and I met this page;
I mean, except from UDE, flash is accesible. But in memtool page, I can't load program, how can I solve UDE problem? I changed some settings from menus but it doesn't work. Everytime like this;
Jun 19, 2017
05:41 AM
Jun 19, 2017
05:41 AM
Hi sumeyye, I would recommend to contact the Free TriCore Entry Toolchain Support at tctcsupport@pls-mc.com. Regards Martin
12:25 PM
Jun 19, 2017
12:25 PM
Yes, I asked these questions to PDH and I'm waiting reply. Thanks again. Best regards.
Feb 05, 2018
02:29 AM
Feb 05, 2018
02:29 AM
I am working on TC29X controller. Unfortunately boot mode headers are erased and I am unable to flash through lauterbcah. I am trying to use miniwiggler and I have connected target using 10 pin DAP connector to miniwiggler. But when I run DAS sevice scanner I see "No Device(DAS JDS miniWiggler V3.1)" message. Can anyone please help me ?
Gayathri
Gayathri
