05:38 AM
Oct 12, 2015
05:38 AM
Dear administrator
when I Developed controller by XC2265, I used EEPROM which is AT251N.
I had to see the Hot of Traning document (HOT_XE164FM_EEPROM.pdf)
so I used DAVE tool (ver 2.0)
as below
U0C1_SCTRH = 0x0707; // Sets frame length on 2 byte
U0C1_SSC_vSendData1(0x06); // Enables write mode
U0C1_SCTRH = 0x070F; // Sets frame length on 4 byte
U0C1_SSC_vSendData1(0x01); // Sets status register ready to write
U0C1_SSC_vSendData1(0x02); // Resets array adresses protection
while( U0C1_SSC_uwGetData() ) // Waits till writing has ended
U0C1_SSC_vSendData1(0x05); // Reads Status Register
U0C1_SSC_vSendData1(0x00);
// Writes data in EEPROM
U0C1_SCTRH = 0x0707; // Sets frame length on 1 byte
U0C1_SCTRH = 0x071F; // Sets frame length on 4 byte
U0C1_SSC_vSendData1(0x02); // Introduction for WRITE
U0C1_SSC_vSendData1(0x00); // Memory of EEPROM
U0C1_SSC_vSendData1(wriValue); // Transmit data
U0C1_SCTRH = 0x071F; // Sets frame length on 8 byte
U0C1_SSC_vSendData1(0x03); // Enables read mode
Page 27
U0C1_SSC_vSendData1(0x00);I recently used documents.
recValue = U0C1_SSC_uwGetData();
we recently used Tri-core 1767.
and we bought Tri-core 1767 EV kit included EEPROM(AT251N).
and we need to use EEPROM(AT251N) working by SPI communication
but we can't working using Existing sources.
we tried to find 32-bit Tri-core register like "U0C1_SCTRH"
but we can't
so please help us.
if you can, would you like to offer source to us.
If hard, please let me know register used to SPI communication
as below
Page 27
but we can't
so please help us.
- tc1767 eeprom
09:39 PM
Oct 12, 2015
09:39 PM
solved solved solved solved
