TASKING GNU C Linker Script: REGION_MAP / CORE_SEC function help
ja1
First reply posted 5 questions asked 5 sign-ins
I am curious as to what the REGION_MAP/CORE_SEC functions are doing behind the scenes. I am trying to port the Lcf_Gnuc_Tricore linker script to work with a Clang / LLVM compiler and linker, and these directives are not recognized. Any insight into what this function does would help me be able to write an equivalent script in LLD based linker commands!
*Note: LLVM LLD is / should be compatible with GNU LD.*
Code section(s) in question:
/* map local memory address to a global address */
REGION_MAP( CPU0 , ORIGIN(dsram0_local), LENGTH(dsram0_local), ORIGIN(dsram0))
REGION_MAP( CPU1 , ORIGIN(dsram1_local), LENGTH(dsram1_local), ORIGIN(dsram1))
REGION_MAP( CPU2 , ORIGIN(dsram2_local), LENGTH(dsram2_local), ORIGIN(dsram2))
CORE_ID = CPU0;
    SECTIONS
        CORE_SEC(.ustack) (LCF_DSPR0_START + LCF_USTACK0_OFFSET):
        { PROVIDE(__USTACK0_END = .);    . = . + LCF_USTACK0_SIZE;    PROVIDE(__USTACK0 = .); }
        CORE_SEC(.istack) (LCF_DSPR0_START + LCF_ISTACK0_OFFSET):
        { PROVIDE(__ISTACK0_END = .);    . = . + LCF_ISTACK0_SIZE;    PROVIDE(__ISTACK0 = .); }
        CORE_SEC(.csa) (LCF_DSPR0_START + LCF_CSA0_OFFSET):
        { PROVIDE(__CSA0 = .);    . = . + LCF_CSA0_SIZE;    PROVIDE(__CSA0_END = .); }
Using: Clang TriCore compiler, TC162 architecture (TC 375 Lite kit), LLVM LLD linker script.
Best,
ja1
Yuva
250 replies posted 250 sign-ins 100 solutions authored
We request you to check with Hightec regarding this topic.
Yuva
