AURIX™ Forum Discussions
nsyed
50 sign-ins First solution authored 25 sign-ins
Do AURIX TC3xx has any in-built progressive clock switching for PLL’s ? or should this be handled in the application SW ?
By progressive clock switching, I mean switching PLL to target frequency in incremental steps, rather than a single big step.
When switching to high frequencies (300Mhz) a sudden ramp up of the PLL clock could increase power consumption leading to voltage drops on the power-supplies, this becomes critical especially during low 12V due to cold conditions.
I would like to use the automatic/built-In feature if available instead of implementing it in the application SW.
NeMa_4793301
Level 6
Level 6
There's nothing built in. The MCAL and iLLD both have examples of ramping the K2 divider up. A 50 us delay in between steps avoids power dropouts.
nsyed
Can you please provide the example codes which you are referring to ? I don't have access to MCAL or iLLD, from where can i get these examples ?
MoD
250 sign-ins 25 likes received 50 solutions authored
You can download the iLLDs and Demos from myicp.infineon.com in the software documentation section
I expect that you have already access to myicp.
NeMa_4793301
Level 6
Level 6
For the MCAL, see src/Mcu.c, Mcu_lSwitchToDesiredFreq().
For the iLLD, see scu/std/IfxScuCcu.h, IfxScuCcu_distributeClockInline().
nsyed
Thank you so much , Appreciate your help.
