AURIX™ Forum Discussions
User13528
Hi
I have a Tricore AUDO board which I upgraded from a TC1767 to TC1782 by replacing the processor and TLE7368-E I appear to be able to get my code running after commenting out the initial MAIN_vResetCheck() function created by DAvE it appears to lock up and prevent jtag from working when I goto Prescaler mode .
This board has been working fine when a TC1767 and is basically the EasyKit TC1782 board
When I put it into SCU_PLLCON0.bits.VCOBYP = 1; // set VCO bypass (goto Prescaler Mode)
I have a 20Mhz Crystal across XTAL1-2
Also before switching to bypass I reset VCO and disconnect OSC from PLL
SCU_PLLCON0.bits.VCOBYP = 0; // reset VCO bypass
SCU_PLLCON0.bits.SETFINDIS = 1; // disconnect OSC from PLL
debugger will no longer break
Carl
User13528
It turned out to be a dry joint on the XTAL pin so hardware not software.
