AURIX™ Forum Discussions
User17459
5 replies posted First reply posted First question asked
hello, I'm a novice in tricore environment, I'm not sure what is the difference between swframework tool and bifaces, both use the same illd ... could someone explain what is the advantage of using one or the other?
User13290
First solution authored
Hi Juan,
BIFACES is the successor of IFXSWF. Its most notable change is that some of its configurations are now driven by XML configuration files. If you use Infineon's IDE you can easily change those through its integrated XML editor.
There are also small changes in the folder structure. But other than that it's pretty much the same. In all you should use BIFACES from now on. If you happen to build an IFXSWF example within the BIFACES framework it will issue a warning telling you that you are about to build an outdated example within the BIFACES framework. Generally though, it will build without error.
Henk-Piet Glas
Principal Technical Specialist
Embedded Software
User17459
Hi, thanks for your quick response and thanks for your help
User13290
Hi Juan,
No problem. Happy to help.
Henk-Piet Glas
Embedded Software
