Is there any function or any way to make sure that the core1 is stopped and no code is executing ? I would like to do this in order to write the PFLASH, from core0.
Thank you!
See Table 294 CPU Power Management in the TC3xx manual (PMCSRy.REQSLP=1).
In practice, it's a little tricky, because if you have a CPU watchdog enabled, it will likely expire if you force a CPU to idle. Also, any interrupts for a CPU will also wake it up. To be absolutely safe, it's best to execute from RAM.
This could also be handled with a higher level software routine, where a CPU polls a flag, and then disables interrupts and enters a very small loop (to avoid accessing PFLASH), polling the flag until it's released by the CPU doing the programming.
