Oct 27, 2020
11:35 AM
Oct 27, 2020
11:35 AM
I have a problem regarding two SSH instances ( DAM0- CPU1DMEM1).
I configured the UCB PROCONRAM to Init All and Selected all memories (PSPRS,DSPRS,PCAHCHE,DCACHE,LMU,DAM) to be auto initialized on warm and cold power on.
for all SSH instance the MTU.FAULTSTS Register the OPERR bitfield holds a value that indicates Auto data init is selected for these memories, however for DAM0 and CPU1DMEM1 the Auto data init bit field is not set in the FAULTSTS register which in consequence the Firmware check is failing.
What would lead something to bypass the configured UCB to auto init all memories including CPU1DMEM1 and DAM0 and would not initialize it on startup?
