AURIX™ Forum Discussions
Ikavalis
First like given 5 sign-ins First reply posted
Hello.
I am trying to establish communication via SPI between the tc234 mcu and tle8242.
According to datasheet, tle captures data on rising edge and shifts data also on rising edge.
The above does not match any of the known SPI modes I have read about (all the modes sample and shift data on alternate edges of the same cycle).
How do I handle this on MCU side? Is there some way I can configure this to match the tle?
So far I have tried to use CPH = 1 (to my understanding this is used to shift data on leading edge) but this doesn't seem to work.
The only configuration that seems to produce any results is setting CPH = 0, A = 2, C = 2, B = 0 which leads to tle responding with message #0 which is a response to invalid message.
Anything else leads to tle responding with message #0 but shifted 1 bit to the left (I guess this is because I'm reading it wrong).
The baudrate I am trying to use is 1MHz, but I have also tried larger and smaller rates and I don't think this is the issue.
Any insight would be appreciated.
Thank you very much in advance
Aiswarya
50 replies posted 100 sign-ins 10 solutions authored
Could you please let us know the value of clock polarity that you are using?
Aiswarya.
Thank you for the response.
I am using 0 as CPOL value.
Aiswarya
Could you please share the waveforms and  register view of  BACON and ECON registers?
Aiswarya.
