AURIX™ Forum Discussions
DonaldH
First question asked Welcome!
I know that this is a basic question, but when you can not figure them out it becomes extremely frustrating.  In the user manual (TC3XX) I find that to get an edge level interrupt/event, you configure the ERU, which has 7 modules/channels for this.  And each channel has 6 selectable inputs (I assume this means pins).  But in the paragraph it says that 'The available trigger sources and defined target modules are defined in the SCU Appendix for each device under the headline "Connectivity".'
I am having a hard time however locating this appendix.  Can you give me a document name for this information.  Thank you.
MoD
250 sign-ins 25 likes received 50 solutions authored
LaneYE
25 sign-ins 10 replies posted 5 replies posted
Hi, Donald
You could find out the relationship between ERU with pin.
