Please provide a sample code to be built on Tasking IDE for evaluation kit "kit_a2g_tc332_5v_trb".
Thank you,
aditya
Hi Aditya,
as far as I know the evaluation kits are only supposed to be used with the AURIX Development Studio.
Within this IDE you have also the TASKING compiler integrated. If you want to skip over to TASKING IDE, you should start with an empty project which supports the TC332 and just compile and load it from there. The way how the program code is implemented differs slightly for both IDEs. That's why you can not directly share sample code between them. But, a good workaround is just to start a new project inside the TASKING IDE and copy your sample code out of the AURIX Development Studio into that project. Sample code for your evaluation kit should be available for download, but only for use with AURIX Development Studio.
TBencher
