Value of STMEM3 as example after Cold power on reset is A0F3FB1F in user manual but while debugging it's value 0x80f3ff1f
problem in bit 10 which must be reserved 1 , and bit 29 which indicate Flashcon1 register check is started
how i solve problem of reserved bit and how start Flashcon1 register check ?
How did you set the BMI?
yes it's enabled, all another's checks are started and passed successfully only the Flashcon1 register and bit10 which is reserved bit
how are you checking SCU_STMEM3?
did you use Trace 32 with PER file? or memory dump?
Memory dump , that values after warm reset and also the same problem
um... this is so strange.
how can the bit 10 be high?
I don't understand.
You checked the BMI, too, didn't you?
Did you check other parts besides the CHSW area?
Then there won't be anything wrong...
In my case, there was a problem with other registers during the FW check stage, but there was no STMEM.
That memory dump address is correct. Right?
I think you should contact an Infenion employee.
What problems did you encounter ?
My problem was more of a problem with the Reset Reason being erased after Cold Power Reset than a Register problem. It is Cold Power On Reset, but the MCU recognized it as a different Reset and determined that the Register value was not correct.
In addition, there was a time when System Reset occurred by turning on SMU CLC and performing FW Check, so I changed SMU reset to No reset.
Other than these issues, there has never been an issue like what you said...
