Equip yourself to optimize AURIX™ MCUs for Evs at the EV Webinar. Click here to register.
AURIX™ Forum Discussions
Mmmmmm
First like given 10 sign-ins 10 questions asked
How could i know that MCU Waked up from standby mode state , in application software ?
dw
100 likes received 750 replies posted 10 likes given
If wakeup, the program will run continuously after the reset()
Observe that the microcontroller returns from
Standby mode similar as it would start from a
reset and the application code is executed
again
Please refer to the code and pdf.
Mmmmmm
is "At the exit of standby " mean after wake up or during standby , and if that mean after wake up what  i must check to know this state ?
dw
You could check the tables to know if the system is from a Standby or a Cold Power-On
Mmmmmm
okay i understand the table but can't understand what the meaning of " At the exit of standby mode " is that after wakeup or during standby mode , or the question could be in another form how i know the the state of standby mode exit to compare the registers with the suitable expected .
dw
I think the exit of standby, is like a reset.
Mmmmmm
is that anyway to indicate the reset is cold power on reset or  return from standby mode ?
dw
PMSWSTAT2 you can refer to
Mmmmmm
is the flag cleared via PMSWSTATCLR before application ?
dw
This flag is cleared in IfxPmsPm_startStandbySequenceInFlash, but no found in the ssw()
