How could i know that MCU Waked up from standby mode state , in application software ?
is "At the exit of standby " mean after wake up or during standby , and if that mean after wake up what i must check to know this state ?
You could check the tables to know if the system is from a Standby or a Cold Power-On
okay i understand the table but can't understand what the meaning of " At the exit of standby mode " is that after wakeup or during standby mode , or the question could be in another form how i know the the state of standby mode exit to compare the registers with the suitable expected .
I think the exit of standby, is like a reset.
is that anyway to indicate the reset is cold power on reset or return from standby mode ?
PMSWSTAT2 you can refer to
is the flag cleared via PMSWSTATCLR before application ?
This flag is cleared in IfxPmsPm_startStandbySequenceInFlash, but no found in the ssw()
