Hallo, I have a problem with SPI communication, I am using Triboard_TC357_ADAS_V2.0. I can see the correct data on the scope but I am able to receive the data of a specific frame on the next frame. I don't know what is the cause of that however I believe it has something to do with the triggering of the RX interrupt. I would appreciate if I can get any help regarding this issue. Thanks in advance.
Aurix
Hallo,
Currently the issue is fixed. it was happening as my code was breaking before the receive of the slave message and as a result when the code is continued again I was getting the slave message of the previous frame not the current one.
Hi Zeidan,
Please refer to the below code example available in github:
https://github.com/Infineon/AURIX_code_examples/tree/master/code_examples/SPI_CPU_1_KIT_TC375_LK
It is for TC375LK but can adapt it for your device. In addition to that, as you have a doubt on Rx Interrupt, please check the priorities configured in the example. The configuration of the priorities shall be as like in the example (ERR > Rx > Tx).
Prudhvi.
Hallo Prudhvi,
I checked already the priorities it is as the example, what I can see now that for some reason the TX interrupt is triggered before the RX interrupt even though the RX has higher priority ! also what is weird that for the first transmission there is nothing being received which indicates that only for the first transmission the RX interrupt is not triggered ? Do you have any thoughts on that ? Thanks in advance.
Zeidan
You will also get a TX interrupt when the BACON is written to the TXFIFO.
Hallo,
