Translation_Bot
Currently, SPI Master needs to build multiple sets of Select Pins. Is the following code modification correct?
static void initQSPI2MasterChannel(void)
    IfxQspi_SpiMaster_ChannelConfig spiMasterChannelConfig;
    IfxQspi_SpiMaster_initChannelConfig(&spiMasterChannelConfig, &g_qspiDma.spiMaster); /* Initialize it with default values */
    spiMasterChannelConfig.base.baudrate = MASTER_CHANNEL_BAUDRATE;
    const IfxQspi_SpiMaster_Output qspi1SlaveSelectQspi1 = {
        &IfxQspi1_SLSO0_P20_8_OUT, IfxPort_OutputMode_pushPull,
        IfxPort_PadDriver_cmosAutomotiveSpeed1
    const IfxQspi_SpiMaster_Output qspi1SlaveSelectQspi2 = {
        &IfxQspi1_SLSO10_P10_0_OUT, IfxPort_OutputMode_pushPull,
    const IfxQspi_SpiMaster_Output qspi1SlaveSelectQspi3 = {
        &IfxQspi1_SLSO1_P20_9_OUT, IfxPort_OutputMode_pushPull,
    spiMasterChannelConfig.sls.output = qspi2SlaveSelectQspi3;
    IfxQspi_SpiMaster_initChannel(&g_qspiDma.spiMasterChannel, &spiMasterChannelConfig);
smartconx_target@Q!w2e3r4t5y6u7i8o9p0||/t5/AURIX/SPI-Master-Select-Pin-configure/td-p/689225
Translation_Bot
If you need to use QSPI2 (initQSPI2MasterChannel), then your /CS select pin can only be selected from the following QSPI2 ports:
You can take a look at how to set the QSPI2 master when selecting single channel:
SPI_CPU_1_KIT_TC397_TFT
smartconx_target@Q!w2e3r4t5y6u7i8o9p0||/t5/AURIX/SPI-Master-Select-Pin-configure/m-p/689998
Translation_Bot
Translation_Bot
I separated initQSPI2MasterChannel 1() and initQSPI2MasterChannel 2(), and the Global handle and spiMasterChannelConfig2 of g_qspiDma2 were handled separately. In actual operation, initQSPI2MasterChannel 2() does not work. What if the Master sends data to slave1? , slave2, and pull the Slave Select Pin (CS) low at the same time. How to modify the sample program?
Here is the sample program I modified:
 * \file SPI_DMA.c
 * \copyright Copyright (C) Infineon Technologies AG 2019
 * Use of this file is subject to the terms of use agreed between (i) you or the company in which ordinary course of
 * business you are acting and (ii) Infineon Technologies AG or its licensees. If and as long as no such terms of use
 * are agreed, use of this file is subject to following:
 * Boost Software License - Version 1.0 - August 17th, 2003
 * Permission is hereby granted, free of charge, to any person or organization obtaining a copy of the software and
 * accompanying documentation covered by this license (the "Software") to use, reproduce, display, distribute, execute,
 * and transmit the Software, and to prepare derivative works of the Software, and to permit third-parties to whom the
 * Software is furnished to do so, all subject to the following:
 * The copyright notices in the Software and this entire statement, including the above license grant, this restriction
 * and the following disclaimer, must be included in all copies of the Software, in whole or in part, and all
 * derivative works of the Software, unless such copies or derivative works are solely in the form of
 * machine-executable object code generated by a source language processor.
 * THE SOFTWARE IS PROVIDED "AS IS", WITHOUT WARRANTY OF ANY KIND, EXPRESS OR IMPLIED, INCLUDING BUT NOT LIMITED TO THE
 * WARRANTIES OF MERCHANTABILITY, FITNESS FOR A PARTICULAR PURPOSE, TITLE AND NON-INFRINGEMENT. IN NO EVENT SHALL THE
 * COPYRIGHT HOLDERS OR ANYONE DISTRIBUTING THE SOFTWARE BE LIABLE FOR ANY DAMAGES OR OTHER LIABILITY, WHETHER IN
 * CONTRACT, TORT OR OTHERWISE, ARISING FROM, OUT OF OR IN CONNECTION WITH THE SOFTWARE OR THE USE OR OTHER DEALINGS
 * IN THE SOFTWARE.
/*-----------------------------------------------------Includes------------------------------------------------------*/
#include "SPI_DMA.h"
#include "IfxPort.h"
/*------------------------------------------------------Macros-------------------------------------------------------*/
#define QSPI2_MASTER                &MODULE_QSPI2               /* SPI Master Hardware module                       */
#define QSPI3_SLAVE                 &MODULE_QSPI3               /* SPI Slave Hardware module                        */
#define LED_D110                    &MODULE_P13,3               /* LED D110 Port, Pin definition                    */
#define ISR_PRIORITY_QSPI2_TX       1                           /* Define the QSPI2 transmit interrupt priority     */
#define ISR_PRIORITY_QSPI2_RX       2                           /* Define the QSPI2 receive interrupt priority      */
#define ISR_PRIORITY_QSPI2_ER       10                          /* Define the QSPI2 error interrupt priority        */
#define ISR_PRIORITY_QSPI3_TX       3                           /* Define the QSPI3 transmit interrupt priority     */
#define ISR_PRIORITY_QSPI3_RX       4                           /* Define the QSPI3 receive interrupt priority      */
#define ISR_PRIORITY_QSPI3_ER       11                          /* Define the QSPI3 error interrupt priority        */
#define ISR_PRIORITY_DMA_CH1        50                          /* Define the DMA channel1 interrupt priority       */
#define ISR_PRIORITY_DMA_CH2        51                          /* Define the DMA channel2 interrupt priority       */
#define ISR_PRIORITY_DMA_CH3        52                          /* Define the DMA channel3 interrupt priority       */
#define ISR_PRIORITY_DMA_CH4        53                          /* Define the DMA channel4 interrupt priority       */
#define ISR_PROVIDER_QSPI2          IfxSrc_Tos_cpu0             /* Define the QSPI2 interrupt provider              */
#define ISR_PROVIDER_QSPI3          IfxSrc_Tos_cpu0             /* Define the QSPI3 interrupt provider              */
#define ISR_PROVIDER_DMA_CH1        IfxSrc_Tos_cpu0             /* Define the DMA Channel1 interrupt provider       */
#define ISR_PROVIDER_DMA_CH2        IfxSrc_Tos_cpu0             /* Define the DMA Channel2 interrupt provider       */
#define ISR_PROVIDER_DMA_CH3        IfxSrc_Tos_cpu0             /* Define the DMA Channel3 interrupt provider       */
#define ISR_PROVIDER_DMA_CH4        IfxSrc_Tos_cpu0             /* Define the DMA Channel4 interrupt provider       */
#define MASTER_CHANNEL_BAUDRATE     1000000                     /* Master channel baud rate                         */
/*-------------------------------------------------Global variables--------------------------------------------------*/
qspiDma g_qspiDma;   /* Global handle for QSPI communication             */
qspiDma g_qspiDma2;
/*------------------------------------------------Function Prototypes------------------------------------------------*/
static void initQSPI2Master(void);
static void initQSPI2MasterChannel(void);
static void initQSPI2MasterChannel2(void);
static void initQSPI2MasterBuffers(void);
static void initQSPI3Slave(void);
static void initQSPI3SlaveBuffers(void);
static void initQSPI(void);
static void initLED(void);
/*---------------------------------------------Function Implementations----------------------------------------------*/
IFX_INTERRUPT(QSPI2ErrorISR, 0, ISR_PRIORITY_QSPI2_ER);         /* SPI Master Error Interrupt definition            */
IFX_INTERRUPT(QSPI3ErrorISR, 0, ISR_PRIORITY_QSPI3_ER);         /* SPI Slave Error Interrupt definition             */
IFX_INTERRUPT(DMAChn1ISR, 0, ISR_PRIORITY_DMA_CH1);             /* DMA Channel 1 Interrupt definition               */
IFX_INTERRUPT(DMAChn2ISR, 0, ISR_PRIORITY_DMA_CH2);             /* DMA Channel 2 Interrupt definition               */
IFX_INTERRUPT(DMAChn3ISR, 0, ISR_PRIORITY_DMA_CH3);             /* DMA Channel 3 Interrupt definition               */
IFX_INTERRUPT(DMAChn4ISR, 0, ISR_PRIORITY_DMA_CH4);             /* DMA Channel 4 Interrupt definition               */
/* Handle QSPI2 Error interrupt */
void QSPI2ErrorISR(void)
    IfxCpu_enableInterrupts();
    IfxQspi_SpiMaster_isrError(&g_qspiDma.spiMaster);
/* Handle QSPI3 Error interrupt */
void QSPI3ErrorISR(void)
    IfxQspi_SpiSlave_isrError(&g_qspiDma.spiSlave);
/* Handle DMA Channel 1 interrupt */
void DMAChn1ISR(void)
    IfxQspi_SpiMaster_isrDmaTransmit(&g_qspiDma.spiMaster);
/* Handle DMA Channel 2 interrupt */
void DMAChn2ISR(void)
    IfxQspi_SpiMaster_isrDmaReceive(&g_qspiDma.spiMaster);
/* Handle DMA Channel 3 interrupt */
void DMAChn3ISR(void)
    IfxQspi_SpiSlave_isrDmaTransmit(&g_qspiDma.spiSlave);
/* Handle DMA Channel 4 interrupt */
void DMAChn4ISR(void)
    IfxQspi_SpiSlave_isrDmaReceive(&g_qspiDma.spiSlave);
/* This function initializes QSPI2 in master mode */
    IfxQspi_SpiMaster_Config spiMasterConfig;                           /* Define the Master Configuration          */
    IfxQspi_SpiMaster_initModuleConfig(&spiMasterConfig, QSPI2_MASTER); /* Initialize it with default values        */
    const IfxQspi_SpiMaster_Pins qspi2Masterpins = {
        &IfxQspi2_SCLK_P15_3_OUT, IfxPort_OutputMode_pushPull,          /* SCLK Pin                          (CLK)  */
        &IfxQspi2_MTSR_P15_5_OUT, IfxPort_OutputMode_pushPull,          /* Master Transmit Slave Receive Pin (MOSI) */
        &IfxQspi2_MRSTA_P15_4_IN, IfxPort_InputMode_pullDown,           /* Master Receive Slave Transmit Pin (MISO) */
        IfxPort_PadDriver_cmosAutomotiveSpeed3                          /* Pad driver mode                          */
    spiMasterConfig.pins = &qspi2Masterpins;                            /* Assign Master Pins                       */
    spiMasterConfig.dma.useDma = TRUE;
    spiMasterConfig.dma.txDmaChannelId = IfxDma_ChannelId_1;
    spiMasterConfig.dma.rxDmaChannelId = IfxDma_ChannelId_2;
    spiMasterConfig.base.txPriority = ISR_PRIORITY_DMA_CH1;
    spiMasterConfig.base.rxPriority = ISR_PRIORITY_DMA_CH2;
    spiMasterConfig.base.erPriority = ISR_PRIORITY_QSPI2_ER;
    spiMasterConfig.base.isrProvider = ISR_PROVIDER_QSPI2;
    /* Initialize the QSPI Master module using the user configuration */
    IfxQspi_SpiMaster_initModule(&g_qspiDma.spiMaster, &spiMasterConfig);
/*  This function initializes QSPI2 channel. */
    IfxQspi_SpiMaster_ChannelConfig spiMasterChannelConfig;             /* Define the Master Channel Configuration  */
    spiMasterChannelConfig.base.baudrate = MASTER_CHANNEL_BAUDRATE;     /* Set SCLK frequency to 1 MHz              */
    const IfxQspi_SpiMaster_Output qspi2SlaveSelectQspi3 = {
        &IfxQspi2_SLSO0_P15_2_OUT, IfxPort_OutputMode_pushPull,         /* Slave Select Pin (CS)                    */
        IfxPort_PadDriver_cmosAutomotiveSpeed1                          /* Pad driver mode                          */
    /* Initialize the QSPI Master channel using the user configuration */
    IfxQspi_SpiMaster_ChannelConfig spiMasterChannelConfig2;             /* Define the Master Channel Configuration  */
    IfxQspi_SpiMaster_initChannelConfig(&spiMasterChannelConfig2, &g_qspiDma2.spiMaster); /* Initialize it with default values */
    spiMasterChannelConfig2.base.baudrate = MASTER_CHANNEL_BAUDRATE;     /* Set SCLK frequency to 1 MHz              */
        &IfxQspi2_SLSO5_P15_1_OUT, IfxPort_OutputMode_pushPull,         /* Slave Select Pin (CS)                    */
    spiMasterChannelConfig2.sls.output = qspi2SlaveSelectQspi3;
    IfxQspi_SpiMaster_initChannel(&g_qspiDma2.spiMasterChannel, &spiMasterChannelConfig2);
/* This function initializes Master SW buffers */
    for (uint32 i = 0; i < SPI_BUFFER_SIZE; i++)
        /* Fill the SPI Master TX Buffer  */
        g_qspiDma.qspiBuffer.spiMasterTxBuffer[i] = (uint8)(i + 1);
        /* Clear the SPI Master RX Buffer */
        g_qspiDma.qspiBuffer.spiMasterRxBuffer[i] = 0;
/* This function initializes QSPI3 in Slave mode */
    IfxQspi_SpiSlave_Config spiSlaveConfig;                             /* Define the Slave Configuration           */
    IfxQspi_SpiSlave_initModuleConfig(&spiSlaveConfig, QSPI3_SLAVE);    /* Initialize it with default values        */
    /* Enable DMA mode*/
    spiSlaveConfig.dma.useDma = TRUE;
    /* Set SPI slave DMA channels */
    spiSlaveConfig.dma.txDmaChannelId = IfxDma_ChannelId_3;
    spiSlaveConfig.dma.rxDmaChannelId = IfxDma_ChannelId_4;
    /* Configure SPI slave interrupts */
    spiSlaveConfig.base.txPriority = ISR_PRIORITY_DMA_CH3;
    spiSlaveConfig.base.rxPriority = ISR_PRIORITY_DMA_CH4;
    spiSlaveConfig.base.erPriority = ISR_PRIORITY_QSPI2_ER;
    spiSlaveConfig.base.isrProvider = ISR_PROVIDER_QSPI2;
    const IfxQspi_SpiSlave_Pins qspi3Slavepins = {
        &IfxQspi3_SCLKA_P02_7_IN, IfxPort_InputMode_pullDown,           /* SCLK Pin                          (CLK)  */
        &IfxQspi3_MTSRA_P02_6_IN, IfxPort_InputMode_pullDown,           /* Master Transmit Slave Receive Pin (MOSI) */
        &IfxQspi3_MRST_P02_5_OUT, IfxPort_OutputMode_pushPull,          /* Master Receive Slave Transmit Pin (MISO) */
        &IfxQspi3_SLSIA_P02_4_IN, IfxPort_InputMode_pullDown,           /* Slave Select Pin                  (CS)   */
    /* Assign Slave Pins */
    spiSlaveConfig.pins = &qspi3Slavepins;
    /* Initialize QSPI Slave module */
    IfxQspi_SpiSlave_initModule(&g_qspiDma.spiSlave, &spiSlaveConfig);
/* Initialize Slave SW buffers */
        /* Fill the SPI Slave TX Buffer  */
        g_qspiDma.qspiBuffer.spiSlaveTxBuffer[i] = (uint8)(i + 0x64);
        /* Clear the SPI Slave RX Buffer */
        g_qspiDma.qspiBuffer.spiSlaveRxBuffer[i] = 0;
/* This function initializes the LED */
    /* Set the port pin 13.3 (to which the LED D110 is connected) to output push-pull mode */
    IfxPort_setPinModeOutput(LED_D110, IfxPort_OutputMode_pushPull, IfxPort_OutputIdx_general);
    /* Turn off the LED (LED is low-level active) */
    IfxPort_setPinHigh(LED_D110);
/* This function initializes the QSPI modules */
    /* Firstly initialize the Slave */
    initQSPI3Slave();
    initQSPI3SlaveBuffers();
    /* Secondly initialize the Master */
    initQSPI2Master();
    //initQSPI2MasterChannel();
    initQSPI2MasterChannel2();
    initQSPI2MasterBuffers();
/* This function initializes the SPI and the LED called from Cpu0_Main */
void initPeripherals(void)
    initLED();
    initQSPI();
/* This function ensures the QSPI communication between Master and Slave and checks whether
 * the data transfer was correct or not
void transferData(void)
    uint32 i;
    uint32 error = 0;
    /* Enable SPI Slave for communication */
    IfxQspi_SpiSlave_exchange(&g_qspiDma.spiSlave, &g_qspiDma.qspiBuffer.spiSlaveTxBuffer[0],
                              &g_qspiDma.qspiBuffer.spiSlaveRxBuffer[0], SPI_BUFFER_SIZE);
    /* Start SPI Master communication */
    IfxQspi_SpiMaster_exchange(&g_qspiDma.spiMasterChannel, &g_qspiDma.qspiBuffer.spiMasterTxBuffer[0],
                               &g_qspiDma.qspiBuffer.spiMasterRxBuffer[0], SPI_BUFFER_SIZE);
    IfxQspi_SpiMaster_exchange(&g_qspiDma2.spiMasterChannel, &g_qspiDma2.qspiBuffer.spiMasterTxBuffer[0],
                               &g_qspiDma2.qspiBuffer.spiMasterRxBuffer[0], SPI_BUFFER_SIZE);
    /* Wait until the slave received all data */
    while (IfxQspi_SpiSlave_getStatus(&g_qspiDma.spiSlave) == SpiIf_Status_busy)
    /* Compare exchanged data */
    for(i = 0; i < SPI_BUFFER_SIZE; i++)
        if(g_qspiDma.qspiBuffer.spiSlaveRxBuffer[i] != g_qspiDma.qspiBuffer.spiMasterTxBuffer[i])
            error++;
        if(g_qspiDma.qspiBuffer.spiMasterRxBuffer[i] != g_qspiDma.qspiBuffer.spiSlaveTxBuffer[i])
            error++;
    /* Switch on the LED D110 in case of no errors (LED is low-level active) */
    if(error == 0)
        IfxPort_setPinLow(LED_D110);
smartconx_target@Q!w2e3r4t5y6u7i8o9p0||/t5/AURIX/SPI-Master-Select-Pin-configure/m-p/690172
Translation_Bot
Can you provide complete compilable project files? Also, do you want to make an SPI master (configure two channels) and communicate with two SPI slaves? Please describe your needs in detail.
smartconx_target@Q!w2e3r4t5y6u7i8o9p0||/t5/AURIX/SPI-Master-Select-Pin-configure/m-p/690253
Translation_Bot
Yes, we currently plan to use QSPI in Master mode to specify 16 sets of CS (SLSO) through Programmable to control the IC.
Therefore, you need to find the CS pin how to set up the multi-channel program.
And attach project documents.
smartconx_target@Q!w2e3r4t5y6u7i8o9p0||/t5/AURIX/SPI-Master-Select-Pin-configure/m-p/690270
