AURIX™ Forum Discussions
User11514
I am facing problem with FIFO operation In SPI
How exactly the data are fetched and transmitted in SPI FIFO
I am using SIngle Move Mode and Short Data
((Ifx_QSPI*)spiModule)->GLOBALCON.B.LB = 1; // LOOP BACK mode requested
((Ifx_QSPI*)spiModule)->GLOBALCON.B.EN = 1; // RUN requested
((Ifx_QSPI*)spiModule)->GLOBALCON1.B.RXFM = 0x01;//
((Ifx_QSPI*)spiModule)->GLOBALCON1.B.TXFM = 0x01;//
((Ifx_QSPI*)spiModule)->GLOBALCON1.B.RXFIFOINT = 0x0;
((Ifx_QSPI*)spiModule)->GLOBALCON1.B.TXFIFOINT = 0x0;
function :
ifxSpiModule->BACONENTRY.U = (spiChannel << 28/*CS*/) |
(spiShiftMode << 21/*MSB*/) |
(0 << 0/*LAST*/) |
(31 << 23/*DL*/ | 7 << 16);
ifxSpiModule->DATAENTRY[0].U = buf[0];
ifxSpiModule->DATAENTRY[1].U = buf[1]; // write to transmitter buffer
ifxSpiModule->DATAENTRY[2].U = buf[2];
ifxSpiModule->DATAENTRY[2].U = buf[3];
(ifxSpiModule->BACONENTRY.U)|= 1 << 0;
ifxSpiModule->DATAENTRY[4].U = 0x11111224;
And when I read
temp = ifxSpiModule->RXEXIT.U; // read receiver buffer
buf0 = temp;
buf1 = temp;
buf2 = temp;
buf3 = temp;
when I read the in while (1) loop then buf0, buf1,buf2, buf3 value keeps changing
Can anyone explain me FIFO operation and its behaviour
What does the value change to?
You should read ((Ifx_QSPI*)spiModule)->STATUS.B.RXFIFOLEVEL to read how much data is available, and then read RXEXIT that many times.
User11514
Thanks..I will check with this
User14049
can you please post code for SPI clock and calculation.
