Ralphance
25 sign-ins 5 likes given First like received
Dears:
Regarding the SOTA function, do I need to configure the registers SWAPCTRL and HF_PROCONTP separately in the application? If it is not configured, please tell me the reason。
thank you! ! !
Yuva
250 replies posted 250 sign-ins 100 solutions authored
These registers are configured during the boot and yes you need to program both the UCBs (UCB_SWAP, UCB_OTP.PROCONTP ) corresponding to SWAPCTRL and HF_PROCONTP for SOTA swap functionality.
Yuva
Ralphance
Dear:
    My understanding is that after I configure UCB_SWAP and UCB_OTP.PROCONTP in UCB, I don't need to configure the two registers in the following figure separately, because the configuration of UCBs will be read during booting and then written to the corresponding registers, I Whether the understanding is correct, please help to reply.
Thanks!!!
ugo_8a
10 solutions authored 25 sign-ins 25 replies posted
Hi, I highly suggest contact your FAE and ask for the application note AP32404-Tutorial_Using_the_2nd_Generation_AURIX_SWAP_mechanism_for_SW_updates_Over_The_Air_v1.1
to enable SWAP you need several steps, the application note goes into more details, and it is important to understand and follow  the steps  otherwise you might brick your device PERMANENTLY!
