latheef
5 questions asked 25 sign-ins 10 replies posted
@dw , @Prudhvi_E  @and all ,
I am looking for the SOTA Demo code with Uart interface mentioned in the below post. I have  this AP32465_Standby_contoller_and_standby_Mode_AURIX_v1.0.pdf but it is not same as the one mentioned in the link .
Please let me know the exact application note  or link for this?
Solved: How to get the flashloader program for TC38x serie... - Infineon Developer Community
Di_W
You can find information about the basics of software over-the-air (SOTA) concept using AURIX in the document titled "AP32551 Basics of software over-the-air concept using AURIX."However, if you are looking for the SOTA UART demo code, please reach out to your local Infineon representative or distributors for consultation and assistance.
Di_W
latheef
I mentioned the wrong Application note in my post. I already have this AP32404-Tutorial_AURIX_TC3xx_Using_SWAP_mechanism_for_software_updates_over_the_air_v1.3.0.pdf from my local ifx rep but havent got any on the Uart code. If you could exactly tell me the Application note , I could ask for it.
Di_W
Kindly register on MyICP (My Infineon Collaboration Platform) through the following link:
MyICP Registration Guide
Additionally, you can access the demonstration .zip file by navigating to the following path and link:
Path: AURIX TC3xx/10 AURIX TC3xx HSM/06 Application Notes/
Demo.zip Link
To gain access rights, you need to be promoted by submitting related materials and specifying the path you need to access.
latheef
I already have the access to the link you  posted but it doesn't have the Uart demo code. Please provide the link for that.
Di_W
Just unzip the package you will seeTC38xA_iLLD101110_SwapDemo in side.
latheef
I have seen the code but it only toggles between the active group of banks every time there is a reset. We have a running FBL (0x80000000  - 0x8003FFFF : using CAN to flash app)  and Application (0x80040000 - 0x80A00000) without HSM enabled. Now we want to enable the SWAP A/B ,so please answer the below?
1)  Where should I move the FBL to ? Is it to the 2MB non swappable (marked blue ). I was thinking if there is a UART demo code it would be easy for me to understand and update my current FBL /application.
Please help me to proceed on this.
Di_W
Hi latheef, If the demo project provided does not meet your requirements, please contact your local Infineon representative for further assistance. The demo project involves swap A/B and flash programming, which require additional access rights to obtain.
