Mar 10, 2019
11:34 PM
Mar 10, 2019
11:34 PM
I am trying to configure the SMU using FSP. Whenever I tried to release the FPS using the CMD and ARG, the result of that command is "command failed". I assumed that the SMU is in alert state at startup and that therefore, It should be set to non-failure state to be condifurable and to set the alarms.
Before that configuration attempt, I
- enabled the watchdog timers,
- enabled ENDINIT and safety ENDNITIT
- set the SMU's keys
- configured the Port control registers HWDIR, HWEN and the PCS to 1
- and, the FSP pin as bi-stable protocol.
Do you know If I missed some step?
Thanks in advance,
Asier
Thanks in advance,
Asier
03:53 AM
May 08, 2019
03:53 AM
ReleaseFSP is only a vaild command if the SMU is in START or FAULT state. I expect that you are in RUN state and therefore the command failed.
