Could anyone share the sample use cases and intialization format on SMPS/PMS module in TC3XX ?
A use case would be:
Single source 5 V supply level (VEXT = 5 V) is supported in following topologies.
– EVRC in SMPS mode with external switches and EVR33 in LDO mode with internal pass devices.
The AURIX EVRC in SMPS mode can generate the core voltage of 1.25V. For this I would suggest to first review "Table 288 EVRC Regulator Component Reference and Register Settings" in the User's Manual (AURIXTC3XX_um_part1_v2.0.pdf). Then you could ask more questions.
Thanks for the reply.
Here i am going to implement following scenario.
But i am confused with initialization part.
The question is, where i can initialize the SMPS ?
Shall i initialize immediate after startup ?
or do i need to wait for Clock and GTM module to initialize first ?
Please correct me if i am wrong.
from my analysis, if i initialize immediate after startup phase SMPS will take default configuration for regulator parameters , based on HWCFG[2] pin.
If SMPS mode selected P.ch MOSFET started delivering by keeping N.ch inactive after startup phase.
but how PWM given to complementary drivers ?
will EVRC independently work without GTM and CLOCK module ?
can we initialize the regulator trimming and frequency spreading after startup phase ?
please add points if i am missing anything or do i need to collect more information ?
