AURIX™ Forum Discussions
Onionmad
I struggle to understand how to enable SIMD instructions, or how to verify if this features is being utilized or not.
What is the procedure for working with SIMD code? Does this require any manual configuration or considerations in order to work?
Nambi
250 replies posted First like given 25 likes received
Could you let us know the device being used?
Best Regards.
Onionmad
Hey,
The device device (SoC) we are using is a tri-core TC-397.
As I understand, SIMD is enabled by use of so called packed-arithmetic, where 4x8 or 2x16 instructions will be executed in parallell.
I fail however, to determine whether or not this feature is automatically enabled by the compiler, and since we generate c-code using embedded coder, from simulink models, I would like to find a way to verify the presence of these SIMD/packed-arithmetic operations in the final binaries(built SW).
Any suggestions how I proceed with this?
Onionmad
Hey,
The links are not working, with the following error message:
You are not authorized to access this service
Nambi
Could you follow the procedure mentioned in the below link to get access?
https://www.infineon.com/cms/en/product/promopages/MyICP-platform-for-Microcontroller/
Best Regards.
