AURIX™ Forum Discussions
Mmmmmm
25 sign-ins 25 replies posted First like given
Value of register as example after Cold power on reset is A0F3FB1F in user manual but while debugging it's value 0x80f3ff1f  .
Prudhvi
25 likes received 50 solutions authored 250 sign-ins
The value is expected if you're using the TC39x steps BA and BB. Please see the Errata BROM_TC.H018 in the Errata document for more details. The screenshot cannot be shared publicly however you can check the device specific Errata in the MyICP portal.
Prudhvi.
Prudhvi
Prudhvi.
Mmmmmm
yes i use the TC39x but BROM_TC.H018 is not available in Errata what is the version do you use i use this https://www.infineon.com/dgdl/Infineon-AURIX_TC39x_BD-Step-ErrataSheet-v01_09-EN.pdf?fileId=5546d462...
Prudhvi
The Errata sheet referred is for BD step device. Please see the Errata sheet of the BA and BB step devices.
As mentioned, this is applicable only for the above steps of TC39x.
Prudhvi.
