AURIX™ Forum Discussions
satyanarayana
First question asked Welcome!
Hi , we are going to use SAK-TC333LP-32F300FAA controller in our design following points requires clarifications
1) power consumption of controller during 5V single external power supply condition.
2) we calculated max power dissipation of controller by considering   391ma max current and 5V supply voltage.
    Pd=0.391*5=1.955 W Is this controller withstand power dissipation.
3) Difference b/w hall effect capture, high speed capture, Trap capture, T12 capture
Yuva
100 solutions authored 25 likes received 100 sign-ins
You can refer to the section 'Power Supply Current' in the datasheet which provides current consumption for specific conditions.
For the 3rd question, I guess you are referring to the CCU6 feature, you should find relevant details in the UM part 2.
Yuva
