AURIX™ Forum Discussions
User21871
i'm working with a Application Kit TC2X7 v1.1 with SAK-TC297TF-128F300N BC, for educational pourpose. I'm struggling to find the istruction manual online or in the my infineon section.
Can you help me in some way?
User21871
Yep, i found that one, i’m in search of the list of all peripheral and their api in C for initialization and understand how to use them. Did someone found something about it?
cwunder
If you want trainings you can goto https://www.infineon.com/cms/en/product/microcontroller/32-bit-tricore-microcontroller/ then click or scroll down to Training then for either TC2xx or TC3xx you will find quick trainings or Expert trainings.
teoBits
100 replies posted 50 replies posted 25 replies posted
if you want to start programming for AURIX™, you can get the dedicated Integrated Development Environment (IDE) here: AURIX™ Development Studio
Numerous trainings that teach you how to use the different modules and API (iLLDs) for AURIX are available here: AURIX™ Trainings.
Each training is composed of
  • code part that can be directly imported from AURIX™ Development Studio (To import a code example, use the import function of the AURIX™ Development Studio: File >> Import... >> Infineon >> "AURIX Development Studio Project", select "Infineon Code Examples Repository" and select the code example to be imported.)
  • pdf tutorial, the full list is available here: AURIX™ Trainings.
If you want to get the whole package of code trainings you can also directly clone the github repository: AURIX™ code examples
Finally, if you are not familiar with Eclipse based IDE’s checkout the Getting Started guide!
Hope it helps,
teoBits
