isga_4596741
First like received 10 questions asked 10 sign-ins
Dear Support,
Please help me to check direct replacement to SAK-TC277TP-64F200N DC?
There's no available stocks for this. We need to look for the possible replacement from you.
Di_W
500 solutions authored 1000 replies posted 250 solutions authored
Dear Customer,
For your part number, Operational Temp range is -40 ~ +125C, 292pin package, Triple core,Production device, HSM enabled, 4MB Flash, 200MHz, PG-LFBGA-292, CAN FD ISO FRAME supported.
As above table showed, please pay attention to EEPROM/Total SRAM/LMU/ETH/HSM/CAN FD features, of course the chip ID is also different acoordingly. You can access TC27x_DS_Add_v1.10.pdf  from myICP for details.
dw
Di_W
Dear Customer,
dw
isga_4596741
Based on the table you provided, Is there any direct replacement that you can recommend?
Or the possible replacement need some design changes prior to use?
Di_W
Hi isga,
Any direct replacement needs to be tested which is ensured by the developer,  which also needs the original developer to consider what features the source code implemented. If you didn't know what features the firmware includes, then it's hard to decide.
dw
