AURIX™ Forum Discussions
Atharva
First question asked Welcome!
I would like to route the TOM Channels to TIM as I would like to generate an interrupt with PWM raising edge.
Is it possible to route the TOM Channels to TIM. If yes could you please give the solution for this query
Prudhvi
25 likes received 50 solutions authored 250 sign-ins
Hi Atharva,
According to AURIX TC3xx User Manual (see link below) Chapter 28.4.1 Overview -> Figure 9 TIM auxiliary input multiplexing, the channel has to be fixed, (i.e., TOM0 can only connect to TIM0) in other words a (A)TOMx_Chy can be connected to TIMx_CHy and no other TIM channels for your use case.
The configuration is defined in CCMx defining the Source Selection Register AUX_IN_SRC for TIMx_Chy
https://www.infineon.com/dgdl/Infineon-AURIX_TC3xx_Part2-UserManual-v01_00-EN.pdf?fileId=5546d462712...
Prudhvi.
Prudhvi
Hi Atharva,
Please refer to the below code example available in the GitHub:
https://www.infineon.com/dgdl/Infineon-GTM_TIM_Capture_1_KIT_TC375_LK-Training-v01_00-EN.pdf?fileId=...
Prudhvi.
Prudhvi
Hi Atharva,
Prudhvi.
