Mar 01, 2016
11:22 AM
Mar 01, 2016
11:22 AM
Is it possible to render a AURIX TC7277 brain dead by flashing a corrupted s3 file?
With a debugger I recently flashed a bad s3 file, now I cannot even use the debug port.
If this is the case, is there any way to rescue the device??
Many thanks.
J
Many thanks.
J
09:46 AM
Mar 02, 2016
09:46 AM
Yes, if your TC277 is an A-Step part.
We had this problem in our early development on a TC277 if you flash code without any valid Boot Mode Headers the part locks out the DAP/Debug port.
To revive this part we had to hand it off to our Infineon FAE who took it back to his local office and they were able to serial load in a new program.
I am fairly sure this issue was fixed in B-Step and later parts, thus if your part is a B-Step or later you should be able to flash a new program through the DAP port.
Mar 03, 2016
03:03 AM
Mar 03, 2016
03:03 AM
Thanks for the reply James, will give it a try.
