chadpham75
10 sign-ins 5 questions asked 5 replies posted
Dear teoBits,
I followed thru the demo and understand the code and I made the demo work for my dev-Kit TC377tx.
I have one quick question that I hope you can help me and give me some explanations or pointers
My question regarding the MODULE_SRC.SCU.SCUERU[] array for the source selection.  I tried to read more in the manual to understand why the output channel % 4, since we have 8 output channels.  So with  %4 then the source from 3 will match with channel 7? (technically channel 8)?
Where can I find more information regarding the how-to select the SRC_SCUERUx or the details of the register SRC_SCUERUx?
/* Service request configuration */
/* Get source pointer depending on outputChannel (SRC_SCUERU0 for outputChannel0) */
g_ERUconfig.src=&MODULE_SRC.SCU.SCUERU[(int) g_ERUconfig.outputChannel % 4];
Di_W
500 solutions authored 1000 replies posted 250 solutions authored
Hi chadpham,
Why %4 in above code line, that's because there is 8 output channels and only 4 interrupt source line.
IfxScuEru_OutputChannel_0 = 0 ,
IfxScuEru_OutputChannel_7
So, outputChannel 0-7 will be routed to 0-3 in SCUERU[4]
outputChannel0 - 0
outputChannel1 - 1
outputChannel2 - 2
outputChannel3 - 3
outputChannel4 - 0
outputChannel5 - 1
outputChannel6 - 2
outputChannel7 - 3
typedef volatile struct _Ifx_SRC_SCU
Ifx_SRC_SRCR SCUERU[4];
/**< \brief 0, SCU ERU Service Request ${x}*/
} Ifx_SRC_SCU;
For SRC_SRCR,  which is a 32bit register for interrupt service.
The ERU_IOUTy outputs are signaled through the ERU_INTy signals to the service request control registers SRC_SCUERUy in the interrupt router module (IR); y=3:0.
dw
Di_W
Hi chadpham,
outputChannel0 - 0
outputChannel1 - 1
outputChannel2 - 2
outputChannel3 - 3
outputChannel4 - 0
outputChannel5 - 1
outputChannel6 - 2
outputChannel7 - 3
} Ifx_SRC_SCU;
dw
