AURIX™ Forum Discussions
Zeidan
First like received 5 replies posted 10 sign-ins
Hallo,
I have a problem with my Triboard_TC3X7_ADAS_V2.0 with C357 mounted on it.  The RST pin suddenly turned on always and the board doesn't connect to PLS debugger. is there a solution to this problem or does this mean that the board is damaged forever ? Thanks i advance.
Zeidan
No I was not able to run any code. it was always stuck in reset. The result was that the aurix chip on the triboard was damaged and it needed to change.
Prudhvi
25 likes received 50 solutions authored 250 sign-ins
Hello Zeidan,
Are you able to run any program (demo programs from Infineon if not your code) successfully on the board before? What do you mean by "RST pin suddenly turned on always" ? Does it mean that it is running fine for some time & then suddenly going for a reset ?
Prudhvi
Zeidan
