Dec 15, 2022
12:30 PM
Dec 15, 2022
12:30 PM
TC3xx - ESM[HW]:SYS:SW_ERROR_PIN_MONITOR indicates that the
A component independent from the AURIX microcontroller shall monitor the SW based External Failure Reporting Interface. The SW-based External Failure Reporting Interface provides a fast information about the presence of an internal failure of the microcontroller.
Can you please clarify what are the SW based External Failure Reporting Interfaces ?
Can you please give one example to help better understand this requirement ? I am having hard time trying to understand which interfaces should be used to satisfy this requirement.
Labels
Aurix
01:15 AM
Dec 16, 2022
01:15 AM
This cannot be discussed under public forum since this topic is covered under NDA.
Aiswarya.
