AURIX™ Forum Discussions
nsyed
50 sign-ins First solution authored 25 sign-ins
I am using TC377TP device and I want configure SMU_FSPO pin (P33.8/W14) for SMU error indication to SBC.
The Ctrl configuration is given as “O”. If I configure this pin PCx[4:0] = 10000b (General-purpose output, Push-Pull Output) as shown below, is it ok ?
VincentWan
50 replies posted 5 sign-ins First like received
Hi
Yes, correct.
u should also refer to TC3xx user manual chapters
- 15.3.1.2.3 Interface to the Ports (ErrorPin)
- 15.3.1.3 SMU_core Integration Guidelines
nsyed
Thank you so much for your help. After reading above sections, it is clear to me how SMU interfaces with the Port. I was missing the configuration steps “Set P33_PCSR.SEL8 to 1, Set P33_PCSR.SEL10 to 0”. It makes sense now.
