nsyed
5 likes given 100 sign-ins 50 sign-ins
My MCU is trigerring an unidentified interrupt.  Upon the IR register investigation, I am seeing the below details.
Where can I get the list of different interrupts for TC377 MCU.
I am seeing Interrupt PN = 0x1E. Any thoughts on what is this interrupt ?
INT_LWSR0.ID = 00BC
INT_LWSR0.ECC = 0B
INT_LWSR0.PN = 1E
Kavya_B
10 likes given 25 solutions authored 5 likes given
Hello @nsyed ,
Can you please check the value set for SRC_GPT120T5 register in your software?
It seems like this interrupt is enabled in your software (may be unintentionally).
Reason behind - Why to check SRC_GPT120T5 register particularly in this case?
There are totally 1024 interrupt sources defined in TC37x with a continuous memory allocated for the corresponding SRC registers. The base address of SRC module is 0xF0038000. Please see the below screenshot from TC37x appendix user manual:
From the register log you shared, last winning interrupt ID is found to be 0xBC.
The address of the SRC register corresponding to ID 0xBC is [Base address] + (4 * 0xBC) = 0xF00382F0.
From 'Table 213 Register Overview - SRC (ascending Offset Address)' of Tx37x appendix user manual, you can see that address 0xF00382F0 corresponds to SRC_GPT120T5.
Kavya
nsyed
Hello Folks,
Any feedback on this ? Appreciate your support !!
Kavya_B
Hello @nsyed ,
Kavya
nsyed
Hello @Kavya_B ,
Thank you so much for the explanation. I was able to figure out the underlying cause what was trigerring the GPT120T5 interrupt.
Appreciate your help !!!
