AURIX™ Forum Discussions
nsyed
50 sign-ins First solution authored 25 sign-ins
Are there any examples for CAN based flash programming for TC377 MCU ? If so can you please provide the link
nsyed
Does anyone have this example. If so please share it. Appreciate your help !!!
TBencher
250 replies posted First like given 50 sign-ins
Hi Nadeem,
unfortunately I am not aware of any ready to use example code. But, if you follow the documentation you should
easily find out how it works.
nsyed
JensM wrote:
Hi Nadeem,
Hello JensM,
Can you please point me to the documentation you are referring to ? If you have any flash programming examples that will help as well.
Nadeem.
TBencher
Hi Nadeem,
please have a look at the Aurix code example.
https://github.com/Infineon/AURIX_code_examples/tree/master/code_examples/Flash_Programming_1_KIT_TC...
Jens
TBencher
Hi Nadeem,
you can find all the information related to CAN Bootstrap Loader in the User Manual Part 1.
Jens
