Equip yourself to optimize AURIX™ MCUs for Evs at the EV Webinar. Click here to register.
AURIX™ Forum Discussions
User19218
Hello, i'm working with Aurix TC275 HSM(Hardware security module),it has AES algorithm. But i wonder if i can add my encryption algorithm to it? We can i find related document.
NeMa_4793301
Level 6
Level 6
The HSM has a Cortex M3 CPU core and an AES-128 hardware accelerator. You can implement any algorithm not supported in hardware with the CPU core.
The HSM documentation is available through MyICP. Follow the instructions here to get started:
https://www.infineon.com/dgdl/Infineon-Customer_%20instruction_guide_for_myICP_version_2-ATI-v02_00-...
User19218
Thanks for your help!
User19218
If implement algorithm by program, the speed will be slow compare to the AES-128 with accelerator. Is that right?
NeMa_4793301
Level 6
Level 6
If you were to implement AES-128 in software, it would be about 50x slower than using the hardware accelerator.
FD_aurix
100 sign-ins 100 replies posted 5 solutions authored
Hi All
Someone coul please do a couple of easy example on how the HSM is practically used? How does it work the interaction between the main cores ans the HSM?
Probably it is already explained somwhere in the tons of documentation, I know, but it will be really helpfull to have some practical easy example to start to dig the docs.
