InfiFly100
First solution authored 10 sign-ins First question asked
GTM PWM trigger EVADC mode, and setting the rising edge trigger mode, if a rising edge is generated, will all channels in the ADC Group be triggered simultaneously, or will only one channel be triggered?
Jeremy_Z
250 sign-ins 100 likes received 750 replies posted
Hi @InfiFly100 ,
1) Is my understanding correct?
-- The trigger request can initiate all channel conversations.
Just as the 32.5.2 Triggers and Gate Signals shows.
BR,
Jeremy
Jeremy_Z
Hi @InfiFly100 ,
Analog/Digital conversions can be requested by three request sources and can be executed in
several conversion modes. The request sources can be enabled concurrently with configurable
priorities.
• Fixed Channel Conversion: A request source requests conversions of one selectable
channel
• Channel Sequence Conversion: A request source requests a sequence of conversions of
up to 8/16 (primary/secondary groups) arbitrarily selectable channels
Note: all channels in the ADC Group can't be converted simultaneously, as the converter is one for an ADC cluster.
BR,
Jeremy
Hi Jeremy, thank you for your explanation.
For example, Use the iLLD Function to trigger evadc group0, and add the all 7 channels to the sequence : IfxGtm_Trig_toEVadc
And config the PWM cycle to 1HZ,it means it takes 7 seconds to complete the conversion of 7 channels, Is my understanding correct?
Jeremy_Z
Hi @InfiFly100 ,
BR,
Jeremy
