AURIX™ Forum Discussions
User17612
First like received
Hi All ,
Does the AURIX™ support Quad SPI (QSPI) ?
Thank you in advance
Kind regards
Lucas
#8042000 20078
User18237
Hi Lucas,
The AURIX™ does not support Quad SPI. In the nomenclature of AURIX™ the QSPI represents Queued SPI.
Queued SPI makes it possible to use different SPI configuration depending on the slave. Therefore for each slave transfer for example the data length, parity type and baudrate can be dynamically configured.
Kind regards
Mr.AURIX™
