Mar 29, 2021
01:24 AM
Mar 29, 2021
01:24 AM
What is the difference between Qspi(Queued spi) communication and general Spi communication?
The general Spi communication means the spi communication via ASCLIN module of Aurix series.
If The Aurix MCU wanna communicate with slave devices(such as Motor drvier IC etc) by Qspi communication,
Should those slave devices be included Qspi function?
(Those slave devices are only included general spi function.)
05:48 AM
Mar 29, 2021
05:48 AM
QSPI is generally the first choice of peripheral for SPI. ASCLIN SPI is limited to a single chip select, doesn't support slave mode, and is a bit less flexible in regard to baud rates and sample points.
Mar 31, 2021
02:38 AM
Mar 31, 2021
02:38 AM
I have used the motor driver IC through SPI communication.
The motor driver IC which is controlled by SPI communication via ASCLIN module SPI is working well.
But It is not work well through QSPI(Queued SPI) using DMA module.
I have used it in the same condition as ASCLIN SPI.
I think The motor driver IC has to support QSPI function for QSPI communication between Aurix and the motor driver IC.
Is it right?
Is it right?
Mar 31, 2021
05:59 AM
Mar 31, 2021
05:59 AM
Sounds like a configuration problem. Either QSPI or ASCLIN SPI should be fine.
