AURIX™ Forum Discussions
User14049
What is MRIS - Master mode receiver input select for QSPI0 what it's function.
User11979
MRIS tells the QSPI module that through which port pin the data is received from the slave.
Autosarian
User14049
I want to configure QSPI0 of TC399, do you have any sample code for it.
User11979
Hello KDN,
I'm sorry i don't have any sample code for TC399.
But I think you can download sample code from Infineon site if you have login credentials.
Try it.
Autosarian.
User14049
Can you please share link from where I can download.
MoD
250 sign-ins 25 likes received 50 solutions authored
You can find all information here:
https://myicp-dmz.extra.infineon.com/SitePages/Home.aspx
If not yet done then registration is needed.
NeMa_4793301
Level 6
Level 6
@MoD I think you meant to post the public link 😉
https://myicp.infineon.com/SitePages/Home.aspx
User14049
My QSPI2 chip select is always low and clock is also not getting output.
I am using SLSO1 of QSPI2(QSPI2_MRSTB), what setting should I use in BACON and SSOC resister.
User14049
I am getting problem while reading data from FIFO of QSPI2.
Single data transmission and reception work fine.
User14049
I checked status register, it's showing EXPECT time out error
NeMa_4793301
Level 6
Level 6
Are you using the iLLD, or making your own SPI code? Can you share a code snippet?
User14049
I am using my own code and it's working now in polling mode, I am using BIFACES to write code can you please help me how can I use it in interrupt mode.
