Jan 05, 2019
11:58 PM
Jan 05, 2019
11:58 PM
Hi Reader,
After loading the data into Tx FIFO(Data entry register 0), i am unable to see the content on debugger. I am skeptical whether the data has been loaded or not. Any suggestions to check this?
However i am considering to check the SPI lines at channel level with a logic analyser.
Spi_Regs->Bacon_Entry_Reg = (0 << 28/*CS*/)|(0 << 21/*MSB*/)|(1 << 0/*LAST*/)|(7 << 23/*DL*/);
uint32 buf = 0xCC;
Spi_Regs->Data_Entry_Reg0 = buf;
uint32 buf_1=0x00;
buf_1 = *(uint32*) 0xF0001D90;
Thanks in advance!!!
uint32 buf = 0xCC;
uint32 buf_1=0x00;
04:33 AM
May 08, 2019
04:33 AM
You can't read the TX FIFO. The DATAENTRY register is a write only register. If yiu read the RXEXIT register then you get the next available value from the receive FIFO if there is anything available.
