QSPI ILLD driver not working after update from ILLD 1_0_0_11_0 to 1_0_1_16_1
André
First reply posted 5 sign-ins First question asked
Hi!
I ported an very old SW from ILLD 1.0.0.11 to 1.0.1.16.1 (latest).
After updating the QSPI commuication is not working anymore. I checked the ILLD user documentation but it seems that the configuration / usage has not changed.
BR,
André
Nambi
50 likes received 5 likes given 100 solutions authored
What is the observed issue ? Are you not observing the SPI data as configured/transmitted on the BUS?
After initiating the transmission, you can compare the register dump when using either of the ILLD driver versions.
Best Regards.
Nambi
Best Regards.
