AURIX™ Forum Discussions
NK
5 questions asked 5 replies posted 10 sign-ins
In Aurix TC299TX Datasheet, under section 3.5, '5 V / 3.3 V switchable Pads' pull-up and pull-down current specifications are mentioned for different types of Pad categories. for e.g. Pull-up current for LP 3.3V pad is mentinoed to be 17uA (min.) for test condition, VIHmin; AL and 75uA (max.) for test condition, VILmax; AL and TTL.
1. Are these current sources?
2. Can i say that, Pull-up current for LP pad is still 75uA (max.) for  input voltage < VILmax and 17uA (min.) for  input voltage > VIHmin?
Thanking you in advance.
