AURIX™ Forum Discussions
hitechelectro
First question asked Welcome!
Hello every one
I tried to Program the TC275 starter kit with memtool v5 but can not connect to the kit and shows " can not establish connection to target"
I don't know what setting is needed.
The TC275 is connected directly to the computer and the memtool setting shows it.
Second question: How can I program this board with Miniwiggler v3 via DAP/JTAJ port? The memtool does not show the miniwiggler on the connected device list.
Amir
Prudhvi
25 likes received 50 solutions authored 250 sign-ins
You may refer to a part of the older thread https://community.infineon.com/t5/AURIX/Password-Protected-JTAG-Flashing-Query/m-p/319727sections Memtool Device Setup Part 1 & Memtool Device Setup Part 2 only
OR please refer to steps mentioned in the following document:
https://www.infineon.com/dgdl/Infineon-TOOL_Tutorial_Memtool_XMC1-TR-v01_00-EN.pdf?fileId=5546d46252...
IMPORTANT: The steps mentioned above are for XMC  but you can adapt the configurations such as Target selection etc for Aurix.
Prudhvi.
Prudhvi
Prudhvi.
